Andrea8625
Dec 26, 2022Aspirant
Netgear AV-line Switch "connection refused. Please try again later"
Hi there, I've configurated my GSM4230P AV-Line Switch with the web browser. Worked fine as always. Also, gave it a new IP address. After that, changed the IP on my computer and logged in again v...
schumaku
Dec 26, 2022Guru - Experienced User
In case you intend to use the simplified AV Web UI: Use the port 8080 http://[IP]:8080/
- Andrea8625Dec 27, 2022Aspirant
Unfortunately the port 8080 http://[IP]:8080/ doesn't work either.
It is on the latest firmware version.
