DFD
Dec 13, 2016Aspirant
Netgear Datasheets - packet buffers in megabits or megabytes?
Can anybody explain why some Netgear switch datasheets report packet buffers in Megabits and others report in Megabytes? For example, the M7100 XSM7224's datasheet reports the packet buffer as 16...
- Dec 13, 2016Hi DFD
'Mb' stands for Megabits and MB 'stands' for Megabytes. I am sorry if you are concerned and confused here: one Megabyte is equivalent to 8 Megabits and all of our datasheets are technically exact regarding Switch Buffer sizes.
Let me help: our Buffer is dynamically shared across ports that are used at a certain time. Buffer is usually used when different speeds between ports.
This is right, our datasheets indicate MB when Smart Managed Switches and Mb when Fully Managed Switches. Historically the reason has been consistency in respective competitive environments. I want to thank you for your message, we may want to reconsider that differentiation and unify measurements across our product lines moving forward.
Please let me know if you have any other questions about our 10 Gigabit Smart Managed switches (XS708T to XS748T); or 10 Gigabit Fully Managed Switches (such as M4300 series).
LaurentMa
Dec 13, 2016NETGEAR Expert
Hi DFD
- DFDDec 13, 2016Aspirant
Hi Laurent,
Thanks for confirming. I'm clear on the difference between the packet buffers in the different models I'm comparing now.
Many thanks!
