Pgr's avatar
Pgr
Netgear FS728FP - VLAN traffic isn't flowing
I'm trying to set up separate VLAN's on a new Netgear FS728FPv2 switch. I've never configured VLAN's before.   The switch works fine with the default config, with every port as UNTAGGED at VLAN 1 ...
  • JohnRo's avatar
    Aug 28, 2015
    Hi Pgr,
    Welcome to the community!
    Yes, you will need to configure PVIDs and VLAN membership for this kind of setup to work. See images below for reference:
    First you'll create the VLAN.
    Then, add the members of the VLAN:
    Assign the PVID of  the ports:
    Once you have done creating the VLANs and adding the ports with PVID, remember to go to VLAN1 and untagged the ports you wanted to be assigned to a different VLAN.
    I hope this helps, if you have more questions feel free to ask.
    Thanks,
ProSupport for Business
