Gyuri85's avatar
Gyuri85
Netgear FSM7328S switch
Hi,
There is a switch FSM7328S. The problem with that does not boot from the internal program (FirmWare). Can anyone help? In this case can be re-loaded on the FW? After switching on, the PWR LED yellow light (about 45 seconds) then yellow blinking. The Master led can nnot operating. The serial port can not responding.
Can anyone help me?
Many thanks:
Gyorgy
  • Contact Tech Support. It is most likely bricked and will need to be replaced.
  • Hi,
    After a long trial the COM port responding. The following messages show:
    U-Boot 0.3.0 (Jun 28 2006 - 13:12:54)
    Board: Netgear FSM73xxS
    DRAM: 128 MB
    Flash: 16 MB
    But does not boot on the switch.
    It is likely that the switch is dead? Can not be recovered?
    It's like you have received a "Format" command.
ProSupport for Business
