JonesNG
Nov 05, 2024Follower
netgear gs108tv3 vlan and routing
Hi What is possible for my desired outcome Port1 - VLAN1 Port2 & 3 - VLAN10 Port 4 & 5 - VLAN 20 I would like Ports in VLAN 10 to communicate among ports in Vlan 10 and also to access VLAN1 ...
schumaku
Nov 11, 2024Guru - Experienced User
Even if asked mny times in the wrong section, a GS108Tv3 isn't a Manged Switch class model, much more a Smart Switch to be discused in the Plus and Smart Switches community section please.
Please also understand these switches will do short cut L2+L3 switching+routing, in no ways, these are competing with what you would do on a sophisticated security appliance (in a much more user friendly way - this is more what you should look for IMHO) or a fully managed switch to achieve the same (in a very technical and user unfriendly way).
