ManuelGarcia3
Dec 05, 2022Aspirant
Netgear GS724t V4 import config to Netgear GSM4328PA
Is possible aplly a configuration backup of Netgear GS724T to Netgear GSM4328PA ?
- Dec 07, 2022
Let me share the article below and use it as your guide:
How to configure routing VLANs on a NETGEAR managed switch with shared internet access
DaneA
NETGEAR Community Team
DaneA
Dec 06, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Is possible apply a configuration backup of Netgear GS724T to Netgear GSM4328PA?
No. You might brick the GSM4328PA if you upload the configuration backup of the GS724T into it.
DaneA
ManuelGarcia3
Dec 06, 2022Aspirant
OK DaneA, Thank you very much by the tip.
Its a pleasure to belong Community Netgear!!
Understand that i need create a new configuration on GSM4328PSA.
Any cookbook or technical sheet to configure this switch?.
Is my fisrt implementatión and is very basic, only need make a LAN whith a 7 PCs windows. Is more or less as a HUB config, that all devices see and communicate and also the management console UI of the switch on the same network.
Regards!!!
- DaneADec 07, 2022NETGEAR Employee Retired
DaneA
- ManuelGarcia3Dec 07, 2022Aspirant
Hi DaneA.
Thank you very much for your help.
I read the article and is that I need will implement.
Best regards.
