cryan411
Oct 22, 2024Aspirant
NetGear GS728TP config for Wireless Access Points with 2 SSID's
Walking into a new environment and just double checking all the configs. Switch purpose: 5 POE wireless access points that serve 2 different SSID's that should egress separate internet circuits....
schumaku
Oct 23, 2024Guru - Experienced User
cryan411 wrote:
Port 1 is set to PVID 2 | Admit all frames | Ingress filter - enabled
VLAN MEMBERSHIP (VLAN 1)
Port 1 - blank (no tagged or untagged)...
VLAN MEMBERSHIP (VLAN 2)
Port 1 (Untagged)
Everything seems to work, but just wanna make sure this is best practice on what we need.
This looks a little bit suspect, if not simply wrong or very risky.
A single port can be configured as an access port (VLAN membership [U]ntagged, PVID set) for a sinlge VLAN only, any other VLAN membership must be [T]agged.
This can apply to an AP which is lsop administered over the first untagged VLAN and IP subnet, while the second VLAN is isolated.
For an simple wireless access port you intend to be manged on the VLAN 1 use
Port for the AP:
VLAN 1 [U]ntagged
VLAN 2 [T]agged
PVID 1
Corp-net port (assume you operate it untagged) - this makes up a simple access port for VLAN 2:
VLAN 1 [ ] ... no mebership
VLAN 2 [U]ntgged
PVID 2
Guest-net port (assume you operate it untagged) - this makes up a simple access port for VLAN 1:
VLAN 1 [U]ntgged
VLAN 2 [ ] ... no mebership
PVID 1
Since this isn't a managed switch I've already suggested a moderator to move it to the appropriate community section Plus and Smart Switches Forum section to discuss Smart Switches (T) and Plus Switches (E), including Local and Remote Management
cryan411
Oct 23, 2024Aspirant
Thanks for the feedback. I feel like this is how it's setup, what am I missing? Vlan2 is what is being used for the guest wifi traffic, and I can manage the AP's through VLAN1.
