JonathanChan
Nov 07, 2022Follower
Netgear GS728TPv2
I have my Netgear GS728TPPv2 powering up 20 units of Akuvox C315W indoor monitors. However, all the indoor monitors fails to boot. However, I have tried other Netgear PoE switches GS418TPP and GS510T...
JeraldM
Nov 11, 2022NETGEAR Employee Retired
Thanks for the ping schumaku!
Hi JonathanChan,
Assuming that the GS728TPPv2 units are already updated to the latest FW and hardware checking has been performed already (Factory Defaults, changing Ethernet cables, and PD devices), it's most likely you'll need to request a replacement.
Just to verify, are the switches purchased recently and if so, can they be replaced with your reseller?
If not, please open a support case to further assist you (see KB here for your guidance).
JeraldM
NETGEAR Community Team
- schumakuNov 11, 2022Guru - Experienced User
JonathanChan does these switches PoE+ subsystem work with other PoE equipment? My stomach says this is an interop issue ... dear JeraldM
