IT_VBO
Oct 29, 2015Aspirant
netgear GSM7352s byte error crc check firmware
Hello, I have a netgear GSM7352s (v1) giving me every time with every firmware versions an netgear "1byte error crc" after uploading the firmware throug Xmodem (extra putty). http://kb.netgear...
IT_VBO
Nov 02, 2015Aspirant
Hello,
The warranty is clearly out. But i thinking "the Community" space can helping me to delete the "corrupted files" for doing an successfully the firmware upgrade. Like the KB12803.
Best REgards
VIncent
Jedi_Exile
Nov 02, 2015NETGEAR Expert
You likely have bad flash since the CRC error can also happen if you have bad flash that can't be written correclty to.
First you need to check what firmware you do have on the switch. There is usually an option in boot menu for operation code status. May want to check that and post back what firmware version you have on there first.
Second, the dev OsapiFsUtils command will only work once you are at the enable prompt.
that article is basically to free up space on the flash. You can always flash the backup image to work around that. Make sure you don't try to upgrade to 10.x code since the v1 don't have ability to load that code up. (too old of hardware). Use 8.0.3.x
Davinder
- IT_VBONov 04, 2015Aspirant
Hello,
I tried with theses Firmwares :
gsm73xxs-5.1.1.3.stk
gsm73xxs_6_0_0_15.stk
gsm73xxSv2-8.0.3.34.stk
gsm73xxSh2_8.0.3.49.stk
Everytime "ERROR: Code image size of 1 bytes is invalid."
I cannot load Operational Code "ERROR: Operational code CRC is not valid, you must load new code."
I deleted them with the menu, but same. ( i tried different speed's and different USB to RS232 adapter)
The Puty Connection :
Options available
1 - Start operational code
2 - Change baud rate
3 - Retrieve event log using XMODEM
4 - Load new operational code using XMODEM
5 - Display operational code vital product data
6 - Update boot code
7 - Delete operational code
8 - Reset the system
9 - Restore configuration to factory defaults (delete config files)
[Boot Menu] 1
ERROR: Operational code CRC is not valid, you must load new code.[Boot Menu] 5
ERROR: Operational code CRC is not valid.
[Boot Menu] 6
Do you wish to update Boot Code? (y/n) n
Update aborted.
[Boot Menu] 7Are you SURE you want to delete operational code? (y/n):y
Operational code deleted...
[Boot Menu] 4
Ready to receive the file with XMODEM/CRC....
Ready to RECEIVE File xcode.bin in binary mode
Send several Control-X characters to cancel before transfer starts.
CKCKCKCKCK
XMODEM transfer complete, checking CRC....
Error loading code...
[Boot Menu]
