IT_VBO
Oct 29, 2015Aspirant
netgear GSM7352s byte error crc check firmware
Hello, I have a netgear GSM7352s (v1) giving me every time with every firmware versions an netgear "1byte error crc" after uploading the firmware throug Xmodem (extra putty). http://kb.netgear...
DaneA
Nov 04, 2015NETGEAR Employee Retired
Hi IT_VBO,
As a follow-up to Jedi_Exile's response unto you, make sure to upgrade the firmware via TFTP. Its because HTTP might give CRC errors. Here is the link where to download the latest firmware as well as the list of firmwares for the GSM7352Sv1 (v = version).
Were you able to execute the command "dev osapiFsUtils" via the enable prompt then proceed with it?
DaneA
NETGEAR Community Team
IT_VBO
Nov 05, 2015Aspirant
Hello,
I am connected through the RS232 Consol port with Extra putty for terminal (extra putty permit to send Xmodem files). I try to execut the dev command where i have the boot menu.
I am sure i have an Hardware V1 (GSM7352Sv1 serial numbers start with 18J, 1J9.)
