IT_VBO
Oct 29, 2015Aspirant
netgear GSM7352s byte error crc check firmware
Hello, I have a netgear GSM7352s (v1) giving me every time with every firmware versions an netgear "1byte error crc" after uploading the firmware throug Xmodem (extra putty). http://kb.netgear...
IT_VBO
Nov 05, 2015Aspirant
Hello,
I am connected through the RS232 Consol port with Extra putty for terminal (extra putty permit to send Xmodem files). I try to execut the dev command where i have the boot menu.
I am sure i have an Hardware V1 (GSM7352Sv1 serial numbers start with 18J, 1J9.)
IT_VBO
Nov 09, 2015Aspirant
Hello,
On KB http://kb.netgear.com/app/answers/detail/a_id/22
"For GSM73xxS, instead of using the firmware images available on the NETGEAR support site, first obtain the file “gsm73xs-6.2.0.6.opr” available from URL ftp://downloads.netgear.com/files/gsm73xxs-6.2.0.6.opr. Then, use the following procedure to load the switch with that file. After reboot the switch, upgrade to the 6.3.x.x firmware normally using either TFTP or HTTP from WEB interface, or copy command from CLI. The file “gsm73xxs-6.2.0.6.opr” should only be used for loading the switch using XMODEM and serial console. Do NOT use the file for normal firmware upgrade using TFTP."
Where i can get the “gsm73xxs-6.2.0.6.opr” file please ?
Maybe this is the solution...
