testuser777's avatar
testuser777
netgear m4250 cannot access uboot
The switch boots fine to a login in and everything but I cannot access the uboot command prompt.  Usually there is a prompt to press C to access the uboot but instead I get the gibberish below and then it boots to a normal login.
U-Boot 2016.05-00268-g035b7f9b75 (Jul 03 2022 - 17:35:27 +0530)VerNo=1.0.0.11
3 %
Checking for application
Extracting application from .stk file...done.
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi testuser777
    Sorry for this issue, may it serve to the rest of the Community - for support requests and troubleshooting, kindly reach out to us sending a message (email) to [email protected] and one System Engineer will come back to you and help you fix it.
    Thank you!
    • testuser777's avatar
      testuser777
      Ok, will do and I noticed I said I was pressing C but I meant to say spacebar. I'll email them. Thanks for the reply.
ProSupport for Business
