  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Mishanos,
    I advise you to update the firmware of your M4300-12X12F switches to v12.0.2.20.  You can download it here.  Be reminded that its best to perform a factory reset after upgrading the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version.
    As per release notes of firmware v12.0.2.20, it says that it fixes the issue wherein the M4300-12X12F (XSM4324S) reboots itself without any reason.  Kindly read the release notes of firmware v12.0.2.20 here.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    Mishanos,
    I just want to follow-up on this.  Were you able to update the firmware of your M4300 switches to the latest version which is v12.0.2.20 then performed a factory then reconfigure everything from scratch?
    DaneA
ProSupport for Business
