Bradomski
May 25, 2017Follower
Netgear Prosafe M4300 12x12f Firmware upgrade Path
Hello,
Is there an official firmware upgrade path for these? Im on 12.0.0.15 and want to upgrade to 12.0.2.12. Is it possible to do that directly?
1 Reply
- Retired_Member
Hi Bradomski,
Welcome to the community!
For M4300-12X12F Switch firmware download, you can refer to the link.
It's support upgrading directly from 12.0.0.15 to 12.0.2.12, but the during time of upgrade will be longer than normal firmware upgrade(e.g. 12.0.0.14 to 12.0.0.15). Be attention that not do any operation(power off/on, insert/pull out management cable) during upgrading process. Just waiting web GUI page redirect to login page automaticlly after upgrade process finished.
Hope it can helps!
EricZ
NETGEAR employee
