bitranox's avatar
bitranox
NETGEAR Support XSM7224S OPR Code Needed
Received this switch second hand, appears to be EOL. Switch did not come with operational code, images, or backup images and boots straight to Boot Menu. From my understanding it appears I may need ...
  • bitranox's avatar
    Oct 30, 2023
    Finally I found a solution -
    I took out the Compact Flash card from another XSM7224S and copied the images manually to the broken one - and it works perfectly !
    So if You need the .opr File, it seems to be possible to transfer files directly to the CF-Card of the router.
    Its also a good opportunity to change the CR2032 Lithium Battery.
    yours sincerely
    bitranox
ProSupport for Business
