alexjhart
Jul 26, 2016Aspirant
Re: MLAG not working - XSM7224
I can't reply on the closed thread, so I am following up to https://community.netgear.com/t5/Managed-Switches/MLAG-not-working/td-p/465708 here
I was experieincing the same issue and eventually resolved it. When MLAG wasn't working, I found that the firmware versions were different. I eventually upgraded them both to Firmware Version 11.0.0.18 and the issue was resolved.
Alright, I found that disabling VPC mode on both switches and re-enabling caused them both to go through the election process again, which resulted in the switches having the expected VPC mac address of C0-FF-D4-A7-DA-01, rather than 00-00-00-00-00-00 that they should in web UI, CLI and packet captures. After that, MLAG started functioning as expected. So in my situtation it seems I had to upgrade to the same, latest firmware and trigger a fresh state of VPC, rather than allowing a bad state to carry forward. I'm not sure if the bad state came from mismatched firmware or another bug, but things seem to be working as expected now.
- JohnRoNETGEAR Employee Retired
Hello alexjhart,
Welcome to the community!
Thank you for this update. I can probably edit the old thread and attach this response of yours. This will help other users if they experience the same issue.
Thanks,
- alexjhartAspirant
Perhaps opening the other thread back up is the appropriate action. I may have spoken too soon in saying that this is entirely resolved. I will say the firmward upgrade helped in getting the VPC domain operational, however I am still experiencing some issues with getting the MLAG to actually work the same with a host (while LAG configuration does work just fine).
- alexjhartAspirant
