tantony
Oct 24, 2018Luminary
Netgear switch dhcp
I have two Netgear switches (XS716T and XS728T) connected to a Juniper firewall. When I connect the laptops to the switches, sometimes I get the incorrect dhcp and default gateway. I called Juniper...
schumaku
Oct 24, 2018Guru - Experienced User
Check the switch and disable any DHCP snooping, DCHP static bindings, DHCP snooping persistent entries, ...
tantony
so far, I'm only seeing DHCP snooping, and disabled on both switches. I think I'm having the same issue, I'll double check tomorrow.
I don't have any static bindings etc.
I ran WireShark, and I can see the switches handling dhcp instead of the firewall for some reason.
- schumakuOct 25, 2018Guru - Experienced User
Operating bunches of XS7xxT in core, backhaul, and device access with customers and here at home/office. All fully DHCP transparent, all DHCP is handled by the designated systems for the various VLANs (some on similar security appliances, some on Windows AD Servers) in a transparent way (with hundreds of systems/devices btw.).
Proabbly time for a factory reset and a manul reconfig from scratch?
Without more insight it's hard to help.
