Dan_Epiphan
Apr 03, 2020Aspirant
Netgear XS716T - mDNS / IGMP Snoop / NDI traffic support
Hello, I am considering an XS716T for a test network that will be running NDI traffic. NDI relies heavily on mDNS, and I have read that there are some issues with Netgear switches and m...
Dan_Epiphan
Hello Laurent,
Thank you for your reply!
It is great that you were involved in the NewTek certification and we will consider using the M4300 series for some test activity in our labs; however one of our customers is considering the Smart series as part of their deployment, while we will advise as you stated that the M4300 has been tested with NDI and passes well, we still need to figure out if the XS716T would suffice.
Thank you again,
Dan.
LaurentMa
Apr 03, 2020NETGEAR Expert
Hi Dan
OK thank you
XS716T was not tested with NDI, this is what we know within our ProAV Engineering Services team (reach out when you want at ProAVDesign@netgear.com for any AV network design or installation support). At NETGEAR we didn't test the Smart Managed Pro switches with NDI either. But given the NDI type of mDNS traffic and all the software enhancements we have done on our M4300's to solve the corresponding interoperability issues in the past, I am confirming the M4300's should be the go-to with NDI 1G or @10G in the NETGEAR portfolio.
