Gerchris
May 26, 2023Tutor
Network Switch
I have a router from my provider on 10GB fiber. I want to connect a switch to the 10GB output from the router (the output is RSJ45) cable. Can anyone recommend a good router with input 10GB RSJ and m...
- May 26, 2023
Gerchris wrote:
I have a router from my provider on 10GB fiber. I want to connect a switch to the 10GB output from the router (the output is RSJ45) cable. Can anyone recommend a good router with input 10GB RSJ and minimum 10 ports output to the rest of the house.
10 Gb Internet isn't that common so there may not be many experts around here.
On the router front, try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
Switches might be best discussed in the appropriate section:
Switches - NETGEAR Communities
To find out what Netgear makes, start here:
Network Switches For Home & Business | NETGEAR
michaelkenward
May 26, 2023Guru - Experienced User
and
- GerchrisMay 26, 2023Tutor
Thanks I will try the switch community
