piotrromanski
Apr 11, 2022Aspirant
NMS300 and GS728TPv2
Hi, I have > 30 Netgear M4100 and M4300 switches and some GS110TP in NMS300. Everything works fine (backups&management). I want to add some GS728TPv2 (set different credentials) and try to disco...
JohnC_V
Apr 15, 2022NETGEAR Employee Retired
Hi piotrromanski,
Welcome to our community! 🙂
It seems that you are having issues with your NMS300. May I know if all the backups are not working in any other protocol except for SNMP? Is it not working on all devices or there are specific backups that are not working? May you be able to provide some screenshots?
John
NETGEAR Community Team
piotrromanski
Apr 15, 2022Aspirant
Only GS728TPv2 doesn't work. I can only discover it over SNMP. All others switches comunicate with credentials set at Default credentilas. GS728TPv2 has different web/cli password so I've added new credentilas and perform Quick Discovery and had Failure credentilas.
Some screenshot below.
credentials failureswitches list (without GS728TP)Backup (without GS728TP)All credentilas (lowest - credentials for GS728TP)
- JohnC_VApr 15, 2022NETGEAR Employee Retired
Please do upgrade the firmware of the GS728TPv2 or re-flash the firmware if it is already running on the latest version then reset it to factory default then re-add it to your NMS300.
John
- piotrromanskiApr 19, 2022Aspirant
I've reflashed it (booth images), had newest firmware version, reset default and no luck 😞 The same problem.
- JohnC_VApr 19, 2022NETGEAR Employee Retired
Our L3 engineers suggested having a packet capture when you try to do a backup job with the GS728TPv2 so that we can check what is happening and have it escalated.
John
