piotrromanski
Apr 11, 2022Aspirant
NMS300 and GS728TPv2
Hi, I have > 30 Netgear M4100 and M4300 switches and some GS110TP in NMS300. Everything works fine (backups&management). I want to add some GS728TPv2 (set different credentials) and try to disco...
piotrromanski
Apr 15, 2022Aspirant
Only GS728TPv2 doesn't work. I can only discover it over SNMP. All others switches comunicate with credentials set at Default credentilas. GS728TPv2 has different web/cli password so I've added new credentilas and perform Quick Discovery and had Failure credentilas.
Some screenshot below.
credentials failureswitches list (without GS728TP)Backup (without GS728TP)All credentilas (lowest - credentials for GS728TP)
JohnC_V
Apr 15, 2022NETGEAR Employee Retired
Please do upgrade the firmware of the GS728TPv2 or re-flash the firmware if it is already running on the latest version then reset it to factory default then re-add it to your NMS300.
John
NETGEAR Community Team
- piotrromanskiApr 19, 2022Aspirant
I've reflashed it (booth images), had newest firmware version, reset default and no luck 😞 The same problem.
- JohnC_VApr 19, 2022NETGEAR Employee Retired
Our L3 engineers suggested having a packet capture when you try to do a backup job with the GS728TPv2 so that we can check what is happening and have it escalated.
John
Ok, I'll try to caputre packet at my NMS300 server.
