Intern00b
Apr 07, 2021Aspirant
Only 100mbps from GS108PEv3 to WAX610Y while 1000mbps is coming from modem
Hi there, I've saw some threads about this subject but I couldn't find a solution for this: I have my standard ISP router (Arcadyan Experia Box V10A) connected to a GS108PEv3 and according to...
schumaku
Apr 07, 2021Guru - Experienced User
With the GS108PEV3 and WAX610Y are on the current firmware and the issue persists, open a support ticket on https://www.netgear.com/support/contact.aspx
Keep us updated here on the subject please.
- Intern00bApr 08, 2021Aspirant
UPDATE: I've exchanged the PoE switch for a GS305EPP since I thought the problem might be in the fact that the former switch only had 802.3af as output (there was a notification in the management tool that the AP was in low power mode).
Unfortunately, still 100M at on the cable from the switch to the AP...
Also contacted support about this.
