osu
Jun 26, 2025Follower
OOB Management ACL
Hello all,
I am trying to create an ACL to apply to the service port.
Through the command line, I am able to make a management acl using the "management access-list" command. After making the ACL, when trying to make rules, there is no serviceport option after typing the ip-source for the rule.
Then, when applying the ACL through the "management access-class name" command and trying to access the switch through ssh from an ip not on the list, I am able to access the switch. The ACL says no packets were filtered.
The serviceport is the only connection available from outside of the switch.
I am using an AV4250 switch.
Thanks.
No RepliesBe the first to reply
