WojtekC
Apr 26, 2021Guide
PoE 802.3af Standards A or B - workaround
I have found better workaround to problem described in thread:
https://community.netgear.com/t5/Managed-Switches/PoE-802-3af-Standards-A-or-B/m-p/1769938#M8154
Solution was tested only on devices mentioned in thread: Nethear M4300-28G-PoE+ with a dozen UniFi UAP-AC-M.
To make these devices work properly, You need to prepare a special patchcord, where wires 4,5,7,8 are connected through capacitors, so they don't interfere with PoE. As capacitor I've used 10n/100V multi layer ceramics.
Solution was tested on two switches with 8 devices, and works for couple months.
I hope this will be useful for someone.
1 Reply
