WojtekC
May 16, 2019Guide
PoE 802.3af Standards A or B
Does the M4300-28G-PoE+ support PoE 802.3af with variant A or B, or maybe both?
A or B refers to https://en.wikipedia.org/wiki/Power_over_Ethernet#Pinouts
I have PoE device which in particular re...
WojtekC
May 16, 2019Guide
Thank You for a quick reply, but I still have doubts.
This device (UniFi AP) supports passive PoE, as stated in datasheet:
24V Passive PoE (Pairs 4, 5+; 7, 8 Return)
802.3af Alternative A (Pairs 1, 2+; 3, 6 Return)
So if switch will power device on pins 4,5;7,8 (variant B), may not detect it properly, or even damage by putting 50V, where 24V is expected.
If switch puts power on pins 1,2;3,6, then all should be fine. That's why is so important for me, which variant is implemented.
As a last resort solution is possible to connect device with only 1,2,3,6 pins, but then connection speed will be down to 100Mbit, what i want to avoid.
LaurentMa
May 16, 2019NETGEAR Expert
I think the access point manufacturer datasheet is leading to some confusion, and I can attest you will find many reports and feedback on other forums with this access point working fine with perfectly standard 802.3af switches.
- WojtekCMay 16, 2019Guide
Thank You. I'll get the mentioned hardware in about month or so, then report back.
