audiotek
Sep 24, 2016Aspirant
PoE GS108T wit Ubiquiti Rocket M5
I'm trying to get a Ubiquiti Rocket M5 to power up with my Prosafe GS108T. I plug the cat6 into port 1 of the GS108T but nothing is happening. I get ethernet if I use the power injector but no PoE on it's own. Is there a setting I need to turn on in the GS108T for the PoE port 1 to send voltage?
Hi audiotek,
Welcome to the community! :)
The GS108Tv2 is a powered device (PD) and its not a power sourcing equipment (PSE). It can be powered on either by:
1. A device that is IEEE 802.3af compliant (PSE) via port 1.
2. By using the power adapter that came with it.
Since the GS108Tv2 is a powered device (PD), you cannot use it to power on the Ubiquiti Rocket M5 via its port 1.
I recommend you the GS110TP switch because it is a power sourcing equipment (PSE) that complies to the IEEE 802.3af standard. It has 8 PoE ethernet ports and you can use this switch to power on up to 8 powered devices.
For more information about GS108Tv2 and GS110TP, access the links below:
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi audiotek,
DaneA
- audiotekAspirant
Thanks for the reply
Unfortunately I bought the GS108T a few weeks ago. I wish I knew about the other model with PoE
Hi audiotek,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
