marks945
Jan 18, 2017Follower
POE on GS108E
Hi I'm just trying to get power over ethernet on my GS108E prosafe switch. My understanding is that only some ports support POE. I do not see any markings and I looked in the config utility and do ...
DaneA
Jan 25, 2017NETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
