KrustyK
Mar 16, 2018Aspirant
Port Based VLANs not isolated
I Hi, I'm trying to configure port based vlan on netgear m4300 8x8f. According to this tutorial : https://kb.netgear.com/29997/How-to-create-Layer-2-VLANs-on-NETGEAR-ProSAFE-Switches, but there ...
KrustyK
Mar 18, 2018Aspirant
Hi TheEther,
Thanks for the reply, is there any approach to isolate subnets with switch only ?
Best regards,
TheEther
Mar 18, 2018Guru
Even though your switch is a Layer 3 switch, AFAICT, no it has no way of isolating subnets beyond the simple act of putting them in separate VLANs.
Does your router support VLANs?
