bfowler9024
Jan 17, 2016Aspirant
Port Configuration page on GS752TP doesn't work
I can't apply any port configuration settings, such as a Description, Enable/Disable, or Port Speed. The APPLY button does not activate. Also cannot navigate from this page to other settings unless I...
DaneA
Jan 18, 2016NETGEAR Employee Retired
Hello bfowler9024,
Welcome to the community! :)
Let us isolate the problem. Kindly answer the questions below:
a. What browser are you using to access the web-GUI of the GS752TP?
b. Are there any error message/s that came up?
c. Did you try using other browsers like Firefox or Safari to isolate the problem?
d. Did you try using other PC/s or laptop/s?
e. What is the current firmware version of the GS752TP switch?
f. Have you tried to perform a factory reset the GS752TP then reconfigure it from scratch and check if same problem occurs?
I look forward to your response.
DaneA
NETGEAR Community Team
