ebikeeric
Jan 29, 2024Aspirant
Port Rate Control in Kbps
I am trying to create a test environment where I can reduce port speeds to really low data rates. Preferably as slow as 1 Kbps but 10 Kbps would be suitable. Yes, I said "Kbps" not Mbps...this is I...
ebikeeric
Jan 30, 2024Aspirant
bump. Anyone? Buehler?
- schumakuJan 31, 2024Guru - Experienced User
Consider implementing a software bridge, e.g based on iptables, where you can netem and the like:
tc qdisc add dev eth0 root netem rate 56kbit
No way on a real-world low-cost switch, which requires have different capabilities.
- ebikeericJan 31, 2024Aspirant
Thanks for taking the time to respond. It appears Netgear does not allow for this capability without complex command line activity and software - which is not something I can do for this.
Not talking of any physical Netgear (or other brand) switch - much more, I have a small Linux system in mind 8-)
Rate limits on physical switches massively depend on the hardware capabilities. Typically, one can set % numbers, typically in steps of about 5%. Background: Switches are made for fast frame forwarding, not for laboratory type applications - counting frames is a switch competency, not throttling the way you expect.
