G-R
Apr 04, 2022Aspirant
Power requirements for APM408C-10000S
Is there a datasheet for a APM408C-10000S stating power and thermal requirements? Is there a datasheet for a XSM4396K0-10000S stating power and thermal requirements with one APM408C-10000S installed...
schumaku
Apr 04, 2022Guru - Experienced User
The M4300 data sheet says
* PoE Budget depends on number of PSU and APM port cards per switch. Min values above are guaranteed when 6xAPM408P (48x10G PoE+) plus any combination of 6 other port cards. Max values
are guaranteed when only 6xAPM408P (48x10G PoE+) per switch, or less. APS600W provides 600W@110V/220VAC; APS1200W delivers 1,050W@110VAC or 1,200W@220VAC per PSU. The system
consumes 110W, plus 5W per empty slot. APM408C/APM408P consume 38W per port card. APM408F/APM402XL consume 23W per port card.
P.3 https://www.downloads.netgear.com/files/GDC/datasheet/en/M4300.pdf
Note: The usage of 10GbE does make a big jump.
- G-RApr 05, 2022Aspirant
Thanks. Sorry I missed the note at the bottom of the datasheet.
