dstryker
Aug 09, 2011Aspirant
Problem with adding additional ports to VLAN
I have a GSM7352Sv2 switch on which I have a VLAN setup. The VLAN is pretty simple in that it is currently comprised of 5 ports. It is used mainly to separate out ports for an iscsi setup. I am try...
Kelvin
Aug 29, 2011Aspirant
Did you set the PVID of the port to correspond to the VLAN ID?
