uweissbach
Sep 16, 2023Aspirant
Problem with REST-API on M4300
I have a switch with 6 x APM408P on Slot 1-6 4 x APM408C on Slot 7-10 and 2 x APM402XL QSFP+ on Slot 11+12 if I try to get the VLAN configuration with "api/v1/swcfg_vlan_membership ..." I get...
uweissbach
ok. How can I get access to that group? I have some other issues with that API
(not errors but some unhandy functionalities...)
regards,
Uwe
schumaku
Sep 16, 2023Guru - Experienced User
As I said, a moderator can add you to this group, granting the access. The best way to reach the ProAV team is via [email protected].
Thanks again, have a nice weekend !
