vesso
Oct 15, 2018Aspirant
Problems with VRRP interface tracking on M4300-28G
Dear community,
I am trying to set up VRRP on two M4100-28G with latest firmware 12.0.7.7.
I have set up 3 IP based VLAN networks and I am trying to run VRRP in all directions.
There is no prob...
- Oct 29, 2018
Firmware is upgraded and I did have proper access to the switch. I just prefer the web GUI instead of CLI. Unfortunately what you suggested isn't working. I kepp getting the same error.
However my colleagues manage to fihish with this problem. The just create another vlan which includes the interface we want to track. Thus one and the same interface is part of two vlans. After this in vvrp tracking they include the vlan which include only the interface we care about and the magic happens.
I would like to close this post as solved!
JohnC_V
Oct 26, 2018NETGEAR Employee Retired
Switch has a default management VLAN 1. If the management VLAN is changed, then you should connect the PC where the management VLAN is. If you haven't change anything related to management VLAN, then you may connect your PC to any port that is under VLAN 1. You may also upgrade the firmware of the switch so that we may know if it's a kind of bug or something.
vesso
Oct 29, 2018Aspirant
