hoggm2
Aug 10, 2016Aspirant
Prosafe switch GS716T register its warranty replacement?
Just had a replacement GS716T V3 switch supplied under the lifetime warranty. Does anyone know if the replacement has to be registered? I tried to register the replacement, but got the classic: "...
- Aug 11, 2016
The replacement is automatically registered to your profile when the replacement ships out to you. If you log in to my.netgear.com you should see the replacement listed under your registered products.
BrendanM
Aug 11, 2016NETGEAR Expert
