Midaz
Jun 01, 2015Apprentice
Prosafe utility
Hello there, I am having trouble finding the GS108Ev3 and theGS105E switches on the network using the Prosafe utility. I must admit I can not access the GS108Ev3 using the web-interface neither. Th...
RX
Jun 01, 2015Luminary
Midaz wrote: Yes both switches have been reset, oddly now I can access the GS108Ev3 using the web-access mechanism however at the same time the exotic prosafe utility can not find neither of the switches!.
When logging into R7000 and looking at "Attached Devices" sometimes the switches can appear quickly but are gone when pressing "Refresh".
Since the switches appear intermittently under "Attached Devices" and then dissapper. could it be the reason the prosafe utility dont work?
Is there a software firewall installed on your PC like Kaspersky, NOD32 or Norton? If yes, kindly try to disable it and check if the Prosafe Utility can detect both switches.
