franca
Dec 09, 2016Aspirant
rack mount ears for GS716T
Hi any ides of how to get a rack mount kit or "ears" for GS716T switch?
franca
Dec 12, 2016Aspirant
thanks JohnRo the switch was not being used in the rack initially, the ears were thrown away....thus we are looking for replacement.
franca
JohnRo
Dec 16, 2016NETGEAR Employee Retired
Hi franca,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
- francaDec 21, 2016Aspirant
hello
thank you for the replies but I'm not any closer to getting the ears. You said if they are in stock they would ship - but when I try to locate, I cannot. can you supply me with part # or contact to place the order please?
thanks
Franca
- JohnRoDec 21, 2016NETGEAR Employee Retired
Hi franca,
You'll need to register your switch first and contact support. They will supply you the correct part.
Thanks,
- JohnRoDec 26, 2016NETGEAR Employee Retired
Hi franca,
I just want to follow up on this. Were you able to talk with support?
Thanks,
