rhagen
Sep 22, 2026Follower
"Advanced Engineering Certification - Wired Module 14": Multiple VLAN untagged???
Hello, in Netgear Academy, "Advanced Engineering Certification - Wired", Module 14, ports are untagged in VLAN 1; at 06:20, some ports are added untagged to VLAN 10, too. I could only replicat...
schumaku
Sep 25, 2026Guru - Experienced User
rhagen wrote:in Netgear Academy, "Advanced Engineering Certification - Wired", Module 14, ports are untagged in VLAN 1; at 06:20, some ports are added untagged to VLAN 10, too.
Look at the intended port usage for VoIP (a phone) and user devices (like a PC, worksation)
Mike does briefely mention this in his audio comment as "by the server".
In my understanding, this is possible because the VLAN association can be done by the RADIUS server at that point.
Later on, he continues to configure the PVID in the classic way:
Is it just me finding it's not possible to go back to a section already viewed? Instead, one have to exit the activity and go forward over the steps 1 ...14...
