jg75996's avatar
jg75996
Re-creating an RSPAN VLAN on an M4100-50G switch
Hello everyone,   I would like assitance in re-creating an RSPAN VLAN on an M4100-50G switch.   Background information: We have a firewall that we are monitoring network traffic on.  On a previo...
  • Retired_Member's avatar
    Retired_Member
    Jun 06, 2017
    Hi jg75996,
    Could you disable STP mode for port 0/45~0/48 on M4100 and try again?
    Web GUI go to 'Switching'-->'Ports'-->'Configuration', then select port 0/45~0/48, set STP Mode to 'Disable'.
