sosfc
Jun 21, 2017Aspirant
Howto change management vlanid on gs724T
Hi guys, I am trying to modify the management vlan vlanid from 1 to 2500 on a GS724Tv4. Firmware version : 6.3.1.19 I have configured a port (23) with PVID 2500, member of vlans 1 and 2500. Other ...
- Jun 21, 2017
Hi sosfc
Welcome to NETGEAR community!
Configure the port 23 with pvid 2500, add port23 to vlan 2500’s member,then change management vlan id to 2500,you will login the webpage.
But you must connect the port23 as management port. And need to add the port 23 to vlan 2500 with untag. Please try again.
Look forward your reply. :smileyhappy:
NETGEAR Employee
ElaineP
Jun 21, 2017NETGEAR Expert
Hi sosfc
NETGEAR Employee
sosfc
Jun 22, 2017Aspirant
You got it
Thanks
