onyangodt
May 17, 2017Aspirant
M4100 12GF Firmware
Greetings, I have recently upgraded the firmware on my M4100 12GF (GSM7212F Layer 2+ ) switch. The switch will not save any configurations and everytime I reboot the switch it does not save the ...
- May 18, 2017
Hi onyangodt,
Very strange...
Maybe the flash is broken on this M4100.
Please check private message for maintenance commands.
Thanks.
DanielZhang
May 18, 2017NETGEAR Expert
Hi onyangodt,
Factory default operation won't clear flash so the space on this M4100 can't release at all.
We need to release more space on flash for this M4100 to make “save” operation work.
Could you please reference above solution to delete files on flash by manual?
onyangodt
May 18, 2017Aspirant
I've followed the above solution that you provided and still I get the same messages indicated in the above console screenshots. Is there another solution ?
- DanielZhangMay 18, 2017NETGEAR Expert
Hi onyangodt,
Okay.
Let's try another solution.
Try to Delete the unused image.
1. Check current active image.
2. Delete the unused image.
3. Reload.
Please reference following screenshot about commands of CLI.
I will send you some maintenance commands through private message if this new solution won't work.
- onyangodtMay 18, 2017Aspirant
Greetings,
It still is not working.I also have downgraded back to the verions that the switch came with which was 10.0.2.13. Please reference the below screenshots
Hi onyangodt,
Very strange...
Thanks.
