onyangodt
May 11, 2017Aspirant
M4100 Ports 1&2
Greetings, I have recently procured gsm5212p switch and was wondering if it's possible to use the first two ports as regular ports instead of PD ports? is there a configuration that we can use s...
DaneA
May 15, 2017NETGEAR Employee Retired
If ports 1 & 2 of the M4100-D12G-POE+ (GSM5212P) switch is not connected to a PSE (Power Sourcing Equipment) switch and you want it to use it as regular port to connect devices such as PCs, kindly answer the questions below:
a. Is there an error message that appears if you will just use ports 1 & 2 as regular ports?
b. What is the behavior of the port 1 LED light as well as port 2 LED light if you are just using it as regular port?
c. If you will connect a PC to either port 1 or port 2, does it have a connection within the LAN?
d. What is the current firmware version of the M4100-D12G-POE+ (GSM5212P) switch you have?
DaneA
NETGEAR Community Team
onyangodt
May 17, 2017Aspirant
I was wondering if we could use ports 1&2 as PoE ports. Having gone through the configuraitons and reading more about it, I can use them as regular ports. I was just wondering if there is a way to use them as PoE ports. I have the latest firmware on the switch and only one LED is on which indicates its communicating with the PC.
