onyangodt
May 11, 2017Aspirant
M4100 Ports 1&2
Greetings, I have recently procured gsm5212p switch and was wondering if it's possible to use the first two ports as regular ports instead of PD ports? is there a configuration that we can use s...
DaneA
May 23, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to try connecting a powered device (PD) like an access point to either ports 1 & 2 and check if the access point turns on? If yes, what are your observations?
DaneA
NETGEAR Community Team
onyangodt
May 23, 2017Aspirant
DaneA You can use the ports 1&2 as regular ports for a workstation or a device that does not require or is powered by PoE. I have yet to see a setting where you can change it so that you can use ports 1&2 to power PoE Devices.I plugged in an access point as well as an IP PoE phone and they wouldnt power on. Ports 1&2 will however power the switch off a nother poe switch and can act as a reduntdant power supply. The first two ports work great with workstations and you can configure them for radius access an muchmuch more.
