Trollpaw
Jul 08, 2019Aspirant
M4300-12X12F (XSM4324S) needs reboot to access admin interface
Hello. I have a strange issue with a couple of our Netgear Switches. They're of model m4300-12x12f(XSM4324S). They're being used as core switches in the different houses in a business park. ...
DaneA
Jul 09, 2019NETGEAR Employee Retired
As far as I have checked with the NETGEAR Support Team, there are no known issue as per described here in the initial post on the previous firmwares.
DaneA
NETGEAR Community Team
Trollpaw
Jul 11, 2019Aspirant
I got another question if that is alright, in regards to this.
Is it alright to use the old config-file after the update and factory reset, or must I do everything from scratch?
I mean, backup configuration, update, factory reset, reload configuration.
or should i do it another order? or not use the backup config at all after the update?
Regards
Stoffe Eriksson
