mayank7489
Nov 02, 2017Aspirant
Multicast stops working after about 20 minutes
Hello Everyone... We have the following setup.. 1 x XSM7224S-100AJS (M7300) running 9.0.1.42 acting as a Core 2 x M4300-52G ProSAFE 48-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+ acting...
- Nov 28, 2017
Hi Hopchen,
Apologies for the late reply...
Bascially this is the update...
Did everything recommended except the below item 3 as this option was not in my Core..
3. Allow querier mode each VLAN.
Switching > Multicast > IGMP Snooping > IGMP VLAN Configuration > Enable Proxy Querier mode for you VLANs here and click Apply.The site just confirmed that multicast is working fine now... :)
One thing I should mention that when I changed the multicast protocol, my remote connection dropped out for about 30 seconds... But then it came good.
Thanks you very much for your help on this...
Mayank
mayank7489
Nov 14, 2017Aspirant
Good Morning Hopchen,
I just tried with IE, Firefox & Chrome from my PC and it did not work.
Just to Rule out internet/Proxy connection, I tried via my laptop on a 4G connection as well and same result. : (
Do you have Google Drive or one Drive... ?
DaneA
Nov 15, 2017NETGEAR Employee Retired
Hi mayank7489,
I can confirm that the download link posted by Hopchen is working and I was able to download the files.
Kindly click on the attachment (the paper clip icon at the right side of this post) to download the file. It is the same files that Hopchen posted for you and I just saved it as .pdf format so that I could attach it here..
DaneA
NETGEAR Community Team
- HopchenNov 16, 2017Prodigy
Thanks DaneA
mayank7489 - I have also create a Google Drive link (below) in case you want the original docs instead
https://drive.google.com/file/d/1VhxH60gsOrIbirbkCewi68R_kiYI6DgL
Cheers
- mayank7489Nov 16, 2017Aspirant
Hi Hopchen,
I managed to download the documents via Google drive link. Thanks..
Let me digest them..
- HopchenNov 17, 2017Prodigy
No problem mayank7489
Take your time. Please remember that these docs are just some guidelines on how to set it up correctly. It won't necessarily solve your issues straight away, but at least we will have a good base to work and troubleshoot from.
Cheers
