JonesNG
Nov 05, 2024Follower
netgear gs108tv3 vlan and routing
Hi What is possible for my desired outcome Port1 - VLAN1 Port2 & 3 - VLAN10 Port 4 & 5 - VLAN 20 I would like Ports in VLAN 10 to communicate among ports in Vlan 10 and also to access VLAN1 ...
ReneD
Nov 21, 2024NETGEAR Moderator
Hello JonesNG,
And welcome to the NETGEAR Community! 🙂
The only implementation I can think of that suffice your plan is Routing Vlans and IP ACL which you already have mentioned. One other solution that may be possible is to implement private Vlans, however this is only supported on Layer 3 switches. For your configuration of Vlans and ACLs, you can use the link below. Page 265 is for routing vlans and page 404 for IP ACL implementation.
https://www.downloads.netgear.com/files/GDC/GS108Tv3/GS108Tv3_GS110TPv3_GS110TPP_UM_EN.pdf
Have a lovely day,
Rene D
Netgear Team
