ManuelGarcia3
Dec 05, 2022Aspirant
Netgear GS724t V4 import config to Netgear GSM4328PA
Is possible aplly a configuration backup of Netgear GS724T to Netgear GSM4328PA ?
- Dec 07, 2022
Let me share the article below and use it as your guide:
How to configure routing VLANs on a NETGEAR managed switch with shared internet access
DaneA
NETGEAR Community Team
ManuelGarcia3
Dec 06, 2022Aspirant
OK DaneA, Thank you very much by the tip.
Its a pleasure to belong Community Netgear!!
Understand that i need create a new configuration on GSM4328PSA.
Any cookbook or technical sheet to configure this switch?.
Is my fisrt implementatión and is very basic, only need make a LAN whith a 7 PCs windows. Is more or less as a HUB config, that all devices see and communicate and also the management console UI of the switch on the same network.
Regards!!!
DaneA
Dec 07, 2022NETGEAR Employee Retired
DaneA
- ManuelGarcia3Dec 07, 2022Aspirant
Hi DaneA.
Thank you very much for your help.
I read the article and is that I need will implement.
Best regards.
