jg75996
May 22, 2017Aspirant
Re-creating an RSPAN VLAN on an M4100-50G switch
Hello everyone, I would like assitance in re-creating an RSPAN VLAN on an M4100-50G switch. Background information: We have a firewall that we are monitoring network traffic on. On a previo...
- Retired_MemberJun 07, 2017
Hi jg75996,
Could you disable STP mode for port 0/45~0/48 on M4100 and try again?
Web GUI go to 'Switching'-->'Ports'-->'Configuration', then select port 0/45~0/48, set STP Mode to 'Disable'.
Retired_Member
Jun 07, 2017Hi jg75996,
jg75996
Jun 08, 2017Aspirant
Hi EricZ,
I have disabled the ports per your direction...
... and cleared the port statistics. Went home and checked the stats again this morning, and they now show ...
This looks promising!
I then checked our servers, Ntop-NG, SELKS, and OpenFPC and am now able to see traffic coming in to the systems. For example, here is a screenshot from the Scirius server that is plugged into port 0/47:
... and here's one from Ntop-NG on port 0/48 (the traffic from the firewall is in orange)...
I think that change has solved my issue.
Now that it seems to be working, I would like to know if enabling RSPAN for VLAN 500 is still a requirement for this particular setup?
Thank you very much!
- Retired_MemberJun 09, 2017
Hi jg75996,
I'm glad to hear it working now.
I think it's not necesssary to enable RSPAN for VLAN500.
- jg75996Jun 12, 2017Aspirant
Hello EricZ,
I'd like to let you know that I disabled RSPAN on VLAN 500, cleared the statistics on ports 0/45-48, and noticed that the number of packets on ports 0/46-48 significantly dropped again.
Thinking that the change that I made, affected that, I re-enabled RSPAN for VLAN 500, but I don't see the number of packets being duplicated anymore.
Can this issue be re-visited?
Thank you!
- Retired_MemberJun 13, 2017
Hi jg75996,
Ok, well. Could you please provide detailed information as below:
1. Pls screenshot the port statistics for 0/45~48
2. Pls screenshot the Spanning-tree port status for 0/45~48 by GUI 'Switching'-->'STP'-->'Advanced'-->'CST Port Status'
- jg75996Jun 15, 2017Aspirant
Hi EricZ,
I am trying to reply back with screenshots, however, I no longer have the ability to insert images.
Let me see if I can describe to you what I see.
For Item #1, after clearing port statistics and then refreshing after a minute:
Port 0/45: 175235 Total Packets received without Errors
Port 0/46: currently disconnected
Port 0/47: 2983 Packets transmitted without Errors
Port 0/48: 2983 Packets transmitted without Errors
For Item #2:
Port 0/45: Port Forward State - Manual forwarding
Port 0/47: Port Forward State - Manual forwarding
Port 0/48: Port Forward State - Manual forwarding
- Retired_MemberJun 16, 2017
Hi jg75996,
Looks like port 0/47 and 0/48 not forwarding the packet any more. Could you show running config for M4100?
I want to double check the configurations.
- jg75996Jun 22, 2017Aspirant
Hello EricZ,
Sorry for taking so long to respond to your last post.
Here is the running confirugration of the switch as requested:
(M4100-50G) #show running-config
!Current Configuration:
!System Description "M4100-50G ProSafe 48-port Gigabit L2+ Intelligent Edge Managed Switch, 10.0.2.20, B1.0.1.1"
!System Software Version "10.0.2.20"
!System Up Time "6 days 16 hrs 15 mins 50 secs"
!Additional Packages QOS,IPv6 Management,Routing
!Current SNTP Synchronized Time: Jun 22 16:17:08 2017 UTC
vlan database
vlan 200,500
vlan name 200 "Firewall-to-LinkBalancer"
vlan name 500 "RSPAN 1"
vlan routing 1 1
exit
configure
sntp server "0.north-america.pool.ntp.org"
sntp server "1.north-america.pool.ntp.org"
sntp server "2.north-america.pool.ntp.org"
clock timezone -4 minutes 0 zone "EST"
time-range
line console
exit
line telnet
exit
line ssh
exit
no storm-control broadcast
interface 0/1
storm-control broadcast level 5
exit
interface 0/2
exit
interface 0/3
exit
interface 0/4
exit
interface 0/5
exit
interface 0/6
exit
interface 0/7
exit
interface 0/8
exit
interface 0/9
exit
interface 0/10
exit
interface 0/11
exit
interface 0/12
exit
interface 0/13
exit
interface 0/14
exit
interface 0/15
exit
interface 0/16
exit
interface 0/17
exit
interface 0/18
exit
interface 0/19
exit
interface 0/20
exit
interface 0/21
exit
interface 0/22
exit
interface 0/23
exit
interface 0/24
exit
interface 0/25
exit
interface 0/26
exit
interface 0/27
exit
interface 0/28
exit
interface 0/29
exit
interface 0/30
exit
interface 0/31
exit
interface 0/32
exit
interface 0/33
exit
interface 0/34
exit
interface 0/35
exit
interface 0/36
exit
interface 0/37
exit
interface 0/38
description 'Uplink to VMware server @ 192.168.10.4'
vlan tagging 1
exit
interface 0/39
exit
interface 0/40
exit
interface 0/41
exit
interface 0/42
exit
interface 0/43
exit
interface 0/44
exit
interface 0/45
description 'RSPAN port FROM network tap of the Firewall'
no spanning-tree port mode
vlan pvid 500
vlan participation auto 1
vlan participation include 500
vlan tagging 500
exit
interface 0/46
description 'RSPAN port for SELKS IDS/IPS'
vlan tagging 500
exit
interface 0/47
description 'RSPAN port for OpenFPC'
vlan tagging 500
exit
interface 0/48
description 'RSPAN port for Ntop-NG'
vlan pvid 500
vlan tagging 500
exit
interface 0/49
description 'Trunk link to Netgear M4300 port 7/0/41'
vlan tagging 1
exit
interface 0/50
exit
interface vlan 1
routing
ip address dhcp
exit
exit
(M4100-50G) #=======================================================================
Thank you for continuing to look into this issue!
- Retired_MemberJun 23, 2017
Hi jg75996,
Looks like for Port 0/46 and 0/47, missed configuration for 'vlan pvid 500'. Please add this command and try again.
If it still not ok, I suggest remove command 'vlan tagging 500' for port 0/45~0/48.
- jg75996Jun 26, 2017Aspirant
Hi Ericz,
I've added the 'vlan pvid 500' setting back into ports 0/46, 0/47 and 0/48. Cleared the stats on the ports and checked back later in the day after 5 hours.
Here are the results:
Port 0/45: Total Packets received without Errors - 37319568; Packets transmitted without Errors - 1365
Port 0/46: Disconnected.
Port 0/47: Total Packets received without Errors - 0; Packets transmitted without Errors - 433454
Port 0/48: Total Packets received without Errors - 0; Packets transmitted without Errors - 433454.
Looks like it did no have the desired effect.
I will remove the 'vlan tagging 500' for those ports tomorrow.
Thanks!
- jg75996Jun 29, 2017Aspirant
Hi EricZ,
I ended up not taking out the 'vlan tagging 500' command for those ports, thinking it might affect traffic on the default VLAN, VLAN1.
What I did do, was re-enable RSPAN for VLAN 500, then went to Switching -> Ports, re-enabling STP mode for ports 0/45 - 0/48, and then disabling STP mode. After refreshing the statistics for those ports, I can see that packets are being duplicated again as before.
Not sure why I needed to do this type of procedure, but I am now seeing the traffic as I would like it to be.
Thank you for staying up on this topic until now.
- Retired_MemberJun 30, 2017
Hi jg75996,
Ok, thanks for response.
It's good news that the function is working now.
