ehoitinga's avatar
ehoitinga
"Timeout expired, please login again. Window will be closed" message when trying to access GS724TP.
Hi,   I use a GS724TP switch for my home network which has 17 devices connected. To easy up network management I created a HTML page with a clickable map with a link to all my devices in it. When I...
  • Jedi_Exile's avatar
    Aug 10, 2015
    The switch UI likely include javascript code that prevent it from loading in another window and likely results in the execution of login output. Just for test try to change the link to html on your source page instead of javascript window loading function being injected and see if that makes a difference
    <a href="http://switch-lan" target="_blank">http://switch-lan</a>
    and see what happens. Or if you wish to debug if referrer is the issue you can do the test in chrome while using the inspector to watch the function Or you can likely check if the switch has Javascript function to block you by doing a inspector on the switch UI page and check for JavaScript function on loading session
ProSupport for Business
