Quantumn
Sep 29, 2017Aspirant
VLan not VLanning on GS728TP
Have several cameras which I'd like to put on their own vlan. And I have a server that handles those camers, which I'd like on the camera vlan and default vlan. I find that the GS728TP has 3 default v...
- Oct 19, 2017
Here is how it should be configured as shown in the image below provided that all devices are within the same subnet:About port 3 where the camera server is connected on VLAN 4, it should be set as untagged (U) with PVID 4. It should also be set as untagged (U) on VLAN 5 to have communication to the cameras connected to ports 14, 16, 18 and 20.
For ports 14, 16, 18 and 20, it should be set as untagged (U) with PVID = 5. These ports should also be set as untagged (U) on VLAN 4 in order for the camera server to have access to the cameras.
About port 23, I did not know that it is the LAN printer. Port 23 should be on VLAN 4, untagged (U) and PVID = 4.
About port 2, you may set it as a member of VLAN 4 (if ever you want it in VLAN 4) set as untagged (U) with PVID = 4.
You can use the default Voice VLAN for IP phones wherein an IP phone is detected by its OID (Object Identifier) and segment all voice traffic.
About the default Auto-Video VLAN, you can use it applications that run multicast traffic.
DaneA
NETGEAR Community Team
DaneA
Oct 03, 2017NETGEAR Employee Retired
As I understand, both VLAN 4 and VLAN 5 are on the same subnet which is 192.168.111.0/24 and there is no router within your network setup. With regard to this, the applicable setup would be implementing Asymmetric VLAN.
DaneA
Quantumn
Oct 03, 2017Aspirant
It does appear that I need an asymmetric vlan. And that's what I thought I have set up, but it's not working. Here's what I intend: The cameras should dwell in their own private vlan. (vlan5 & pvid5) The camera server should also be in that vlan5 & pvid5 so it can capture video. But the camera server should also dwell on the normal LAN so that video can be watched (via a video application) by other machines in the normal LAN. This video would not be sourced directly from the cameras, but from the application. The aplication would source it directly from the cameras.
So the camera -server- should be able to access both vlans. (4 & 5) But the cameras should be only on 5 and normal machines only on 4. (all defined on the switch ports) And by assigning the camera server to both vlan4/pvid4 and vlan5/pvid5, I thought I had done that. But it doesn't work. I can't ping the cameras from the cameras server.
Yes, cameras and all other machines are in the same class C, although they don't have to be. I can assign two IPs to the cameras server interface if that would be best.
Consider for these purposes that there is no router. One of the other servers actually runs a virtual machine that is the router, but that's not needed in this case.
